Dán sứ veneer tại đà nẵng
Thảo luận trong 'Dịch vụ khác' bắt đầu bởi hoangdat0905, 23/9/24.
Đà Nẵng
69 Tạ Mỹ Duật, Phường An Hải Bắc, Quận Sơn Trà, Thành phố Đà Nẵng, Việt Nam, Đà Nẵng (Xem bản đồ)
23/9/24, 0 Trả lời, 45 Đọc
  1. hoangdat0905
    hoangdat0905 Member
    Porcelain Veneers in Da Nang is a dental solution that helps restore teeth by using very thin porcelain crowns to protect natural teeth. Thereby, this process helps cover tooth pits or fill small gaps caused by cracked tooth. Moreover, Porcelain Veneers also help to recreate the smile, turning once heavily stained and crooked teeth to white, shiny and even ones. If you are looking for a reputable porcelain veneer address, check it out with Nha khoa Đông Tây Tây!
    Veneer sứ là gì?
    Porcelain Dental Aesthetics (also known as Mặt dán sứ) is a method to help protect and restore teeth in cases such as cracked teeth, worn enamel, or severe tooth decay that cannot be fixed with fillings; heavily stained teeth that cannot be whitened normally; and Teeth that are uneven,. This method helps you have healthy, regular, and bright white teeth quickly and the teeth can last up to 10 years.
    Porcelain Veneers service in Da Nang has brought a ‘new layer’ to dental problems, helping to solve problems such as missing white teeth, uneven teeth… to recreate ‘natural beauty’ at the same time making teeth more even and harmonious by using dental porcelain pieces made to look like natural teeth’s color and shape.
    Khi nào bạn cần thực hiện dịch vụ bọc răng sứ tại Đà Nẵng?
    Not every problem with tooth damage requires the use of this protective coating service, as this depends on each specific case and whether or not the Dentist prescribes it. This includes cases where the tooth is seriously decayed, or so severely damaged, that a filling alone cannot fix it (usually for front teeth)..
    The most popular case for treatment of Dental Porcelain Veneers is when the customers’ teeth are heavily stained and yellowish as a result of smoking, using colored food like tea, coffee and also from long-term plaque.
    Công dụng của mặt dán sứ tại Đà Nẵng
    Veneers act as a layer to protect the teeth from cavities, chips, etc, especially for customers that are in their 50-60s. Furthermore, Veneers can help adjust the aesthetic size of teeth for crowded, spaced, protruding or slightly underbite teeth. The most favored use of Veneers is that it can improve tooth color and . Overall, Veneers can help teeth align, improve the cosmetic look of the teeth, bring a bright and shiny smile for customers without the fear of staining it from smoking, tea or coffee. The customers’ oral health is improved and their teeth are better protected, especially when they are elderly people.
    Chi tiết tại: https://eastmeetswestdental.org/vi/veneers-in-da-nang/
