Van điều chỉnh áp suất yoshitake. gd-200c
Thảo luận trong 'Máy công nghiệp, xây dựng' bắt đầu bởi vindec02, 3/6/19.
Số 124 Trần Hữu Dực, Xuân Phương, Q. Nam Từ liêm, Hà Nội, Hà Nội (Xem bản đồ)
3/6/19, 0 Trả lời, 285 Đọc
  1. vindec02
    vindec02 Member
    Van Giảm Áp Bích | Van Điều Chỉnh Áp Suất YOSHITAKE. GD-200C
    Van Giảm Áp Lắp Bích Hãng YOSHITAKE. GD-200C ứng dụng cho nước, nước nóng, dầu, khí hàng chất lượng cao, giá tốt ưu đãi lớn, giao hàng toàn quốc.
    Van Giảm Áp YOSHITAKE: GD-200C
    Pressure Reducing Valve YOSHITAKE: GD-200C
    Pressure Reducing Valve GD-200C
    * Direct-acting type
    * Stable reduced pressure against fluctuation of inlet pressure because of pressure balance mechanism
    * Nylon 11 coating both inside and outside
    Feature Direct-acting type / Nylon 11 coating
    Type Direct-acting type
    Specifications Application Cold and hot water , Oil (kerosene , heavy oil A and B) , Air , Other non-dangerous fluids
    Inlet pressure Max. 1.0MPa
    Reduced pressure 0.05 - 0.7MPa(*)
    Connection JIS 10K FF flanged
    Min. differential pressure 0.05MPa
    Max. pressure reduction ratio 10:1
    Max. temperature 60 degree(C)
    Material Body Ductile cast iron
    Valve & seat NBR & Stainless steel
    Diaphragm NBR
    Remarks
    * Reduced pressure
    (A): 0.05-0.25 MPa
    (B): 0.26-0.7 MPa
    * Trim (Valve seat,Spindle) material [SUS316] is also available (GD-200HS)
    Dimensions (mm) and Weights (kg)
    Size L (mm) H (mm) Weight (kg) Cv value
    15A(1/2) 145 296 8.3 2.5
    20A(3/4) 150 296 8.3 4
    25A(1) 150 318 10.1 5
    32A(1 1/4) 195 398 17.4 8
    40A(1 1/2) 195 398 17.4 12
    50A(2) 195 412 19.3 16
    65A(2 1/2) 270 573 40.1 28
    80A(3) 270 598 43.8 36
    100A(4) 308 666 70.8 68
    125A(5) 380 875 144.1 75
    150A(6) 400 930 173.1 108
    Tags: Van Giảm Áp BíchVan Điều Chỉnh Áp Suất YOSHITAKEVan Giảm Áp YOSHITAKE. GD-200C
    Best regards,
    Mr.Tran Quoc Toan (Sales Engineer)
    M: 0981 966 804 (Zalo | Skype)
    E: sales02@vindec.vn
    W: http://vindec.vn/
    HANOI Office: Room 303, 3th Floor, Building Thong Tan, No.124 Tran Huu Duc Str, Xuan Phuong Ward, Nam Tu Liem Dist, Hanoi City
