What is expanded polystyrene
Thảo luận trong 'Mua sắm khác' bắt đầu bởi 2LIANS RECYCLING, 22/9/23.
Đã sử dụng
111 North Bridge Road #08-18, Peninsula Plaza, Singapore 179098, TP.Hồ Chí Minh (Xem bản đồ)
22/9/23, 0 Trả lời, 110 Đọc
  1. 2LIANS RECYCLING
    2LIANS RECYCLING New Member
    2LIANS RECYCLING PTE. LTD. is one of the popular global recyclers of post-industrial and post-consumer plastic. We are masters of different types of scrap forms to make you satisfied with your requirements.
    If you have any interest, please contact us for good business terms and we negotiate good prices.
    We look forward to any contact(s) in order to establish a long-term business relationship.
    What is Expanded Polystyrene ( EPS) ?
    Expanded Polystyrene also known as EPS is a rigid, thermoplastic foam and closed cell material. It is produced from solid beads of polystyrene, polymerised from styrene monomer and contains an expansion gas dissolved within the polystyrene bead.
    Each solid polystyrene bead has small amounts of gas so it expands when heat (in streaming) is applied, thus forming closed cells of EPS. These expanded cells occupy approximately 40 times the volume of the original polystyrene bead. Then, with a second heat treatment using a mold, large EPS blocks can be molded into specific customized shapes.
    EPS is used for many applications, including:
